MDavis0424
Well, my 2004 V8 sport is back at the dealer for the fifth time in five months, here's a quick recap:
1) Pulling out into traffic, engine stalls. Starts right back up, will idle (very rough) but car won't go more than about 3mph. Codes for throttle position sensor, dealer replaces TPS and throttle body.
2) Less than a week later, cruising along at 40 mph engine stalls. Will restart and rough idle, but car will not even move. No DTCs, dealer unplugs MAF and the car restarts and runs. Replaced MAF.
3) Three weeks later, cruising at 70mph, engine stalls. Will restart and rough idle, but car will not even move. No DTCs. Dealer unplugs MAF, car runs. I mention the problems I have read on this board about #4 coil causing computer interference, they assure me that this is not my problem and will not replace it. Dealer replaced PCM, and drove the car for a week.
4) Another three weeks, cruising along at 55mph, engine loses power but doesn't stall. Will chug along at about 5mph, but if you floor it it takes off at full power. Codes for one bank too rich, one bank too lean. Dealer clears codes and can not duplicate problem. Still not willing to try replacing #4 coil, but agree to swap it to the other side. They drive the car for 2 weeks with a data recorder, then give me the car to drive with the data recorder. Transmission is acting funny, wants to hold gears too long. Also feels like a neutral drop between 2nd and 3rd gear, tach will wind up 1000 rpms then thunks into gear. Transmission will not act up at the dealer of course. After about a month without engine problems the dealer pulls the data recorder, tells me when the transmission is acting up on a regular basis to bring it back.
5) Two months later. Sitting at a traffic light, starts to idle rough. Light turns green, everyone else goes. I chug along with a maximum speed of about 20 mph. I'm less than 2 blocks from the dealer, so I pull it in. Codes for both banks lean and O2 sensor stuck low.
Anyone have any ideas what is going on with this car, the dealer doesn't seem to have a clue. They called it into Ford's tech people, they're the ones who told them to replace the PCM and put the data recorder in, they are clueless as well.
