are power sloted rotors breaks good
  • Thread starter Thread starter bigdog1279
  • Start date Start date
B
bigdog1279
Guest
what do you think about power sloted breaks and cross drilled rotors for a 95 continental i can get the parts on ebay preaty cheap iv sean them set of 4 rotors for under 200 dollars
They'll give you excellent stopping power. Once you even tap the brake slightly, you'll feel the bite. The downsides are; cheap or improporly drilled rotors are prone to cracking due to the instability from the drilled holes. Second, you'll be replacing the pads more often since the holes or slots cut more material off of the pad.
As for the price, $200 on ebay is ridiculous. Try Summit racing for better prices and more reputable products...
bigdog1279 said:
like evil ill agree to slotted if they are radiussed to many crossdrillers dont know squat about doing it correctly.a poorly drilled rotor can crack and fail causing more damage than it is worth. :L
so what would on of the best or do you have a recomend brand for the sloted rotors
