Anyone tried replacing or adding desicant to dryer
That would make for a tight fit. I can barely get mine together the way it is.
How would one know when you have added too much?
easy you count the beads you take out...and replace the exact number of beads from the new batch.
you can get it in bulk at Academy.
Make sure you count the old ones...keeping track of the pink and blue beads.
you MUST put the pink and blue beads back in the dryer with the new beads.
seriously you can get it in bulk at academy though
Well having never opened one up..but now I think I have gathered that it is pretty much packed inside with the dessicant.
Thanks for the tip on Academy.
Actually its not packed. It has a compression spring. The spring compresses the stuff between two plates/filters. That spring makes it a little fun to put back together. Keep in mind this stuff expands, hence the spring. If you were to stuff the dryer and it absorbed moisture - crack!
