Scallywag
Just looking for some tips on removing the crossover tube from the intake mount and how to loosen up the resevoir feed & engine return hoses that connect to the thermostat housing. I am newb when it comes to mechanics.
I'm replacing the crossover due to a leak at the front male/female coupler part of the tube assembly & burping the air pocket that i think is in there is out of the question since the drain plugs square bit insert is stripped and vice grips have done nothing but chew away at the edge. With no torch to heat & with the replacement having arrived today(thank you RAJones), might as well swap it. Only problem is that it's stuck real good to the intake mount & wont come off.
Thermostat because I haven't had any heat & jumpy temp needle. 5 minutes into my 1st drive of the day & the needle jumps up to the first red line for 20 seconds before dropping back to norm. Got radiator and crossover hoses disconnected, but the other ones are a pain to loosen from the housing.
Any tips would be great!
