another question (Fan Relay)
micahs97m8
Browns Mills
I'm not sure which module goes to the fan assembly and someone is asking for the module. Any pointers?
Really should use the search feature a little more.
You can thank 93 for this pic.
is it the same on a 97? I'm not seeing anything near there that looks anything like that.:confused:
no neither is the module, 93-95, then 96 is alone, then 97-98 are the same, yours is located on the air suspension compressor bracket behind your pass front fender, it looks the same as the one pictured above though.
the 97 and 98's are the same LOOKING device, just in a different location.
it's located in the lower bumper cover underneath the passenger side headlight.
