Another Audio Question :)
KC_Valentine
Kansas City
I was speaking with my local audio shop about the two Type R 12" subs I have now.. The guy I was speaking with informed me about the Slash series JL amps.. That they run equally well for 2, 3, or even 4 ohm loads.. They list the 500/1 amp at 599$ new.. I can get it for 475$ ish from them but curious how well they really perform if anyone has tested/used these before?
It is the number 1 selling amp in the country (that particular model). Has more power than the average 500 watt amp. Let me know if you want it tho. I can get it cheaper than that for you. :give
Well I have talked with 2 audio shops and about 4 installers, and they all highly recommend it with these subs, and say that if later I want to switch to just a 10w7 that this is the amp they would recommend for it to, so I am definately getting one. A friend of mine knows the owner of one shop, but I doubt I can get it for under 400. So let me know Galant, I am anxious to get this system going =)
what about the..
JL Audio e1800D I can get it for 389.99 normally 499 +
Class D Monoblock Subwoofer Amplifier
High-Damping Class D Circuit with discrete control circuitry
Pass-through RCA outputs
On-board crossover: Variable Low-Pass Filter: 20 -200Hz, Selectable Slope
High level inputs
CEA-2006 Compliant
RMS Power Rating (14.4V):
4 ohms: 640 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
RMS Power Rating (12.5V):
4 ohms: 480 watts x 1 chan.
2 ohms: 800 watts x 1 chan.
Frequency Response: 10 - 250Hz
Damping Factor: >500 @ 4 Ohms / 50Hz, <250 at 2 Ohms/50Hz
Input Range: 200mV - 8V RMS
Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
Dimensions: 15.75" L x 9.25" W x 2.36" H
1-year Sonic Electronix warranty
