Angel eyes
jt_grignon
buffalo
im looking to get 8k angel eyes. I was wondering which ones will fit a 2002 LS. Any help would be great.
if you go on lskoncepts.com you might be able to find some, good luck gettin them installed if you dont even know how to take the amber out of your headlight though, might want someone professionally do it for u. also wtf r u a jap ricer that u want to get 8k? get 4.3k or 5k itll look so much better and not like a ghetto loser show car......also take a look at my official ls owners guide to answer some of your questions....
I think 80 is too small.I put 80 on my fogs
You have to make sure you have grey sealant - so that you can bake the lens apart - otherwise you are cutting the lens off and re-gluing. On my Gen1 I use rings for an E36 whick allows me to use the outside / inside of the bezel.
Yep.. I have the gray sealant.. The lights are also leaking.. Do you know were I can get the clear corners or would you recommend me tinting the ones that I have? The reason I was asking sizes was that there was a kit for under 50 that had 4 angels and 2 trans. and wiring.. I thought about it and if they break, I'm screwed.. It's not just a simple tear-down and fix once it's sealed..
clear corners are simply popped out amber lenes - so once you get the light housing apart you pop out the amber lenes.
I buy mine off ebay - and when they break - you just do it again..... ;)
That's were I was going to get them at.. Isn't there like a clear lens or something.. I think I saw it on LSKoncepts but they say out of stock for an underterminded amount of time.. 200 just seems like a lot but maybe that's what they are running for.. I haven't checked prices on them for awhile..
I would say go with umnitza LED's. They may be more expensive but are worth it. I bought some regular CCFL inline for 35 bucks and they look good at night, but are not that visible in the day. The unmitzas almost blinded me in the day time, super bright. It is all up to you, but do you really want to keep opening up the headlight cause the CCFLs keep going out or they wont turn on during cold weather.
