Angel Eyes wiring?
Lucky_Ls
Round Rock
I just received my Angel Eyes kit the other day and am planning on installing them in a couple of day. However, I have one question before I begin. How do the majority of you have your Angel Eyes wired up? I noticed the kit comes with T-Taps, the Ballasts and the full wiring harness. Obviously these kits were ment for a BMW so I’m not going to be able to use everything that comes in the kit, right? According to the online installation instructions from Lskoncepts.com I have multiple choices. How did you guys wire it up?:confused:
wired straight into turn signal bulbs. make sure u tap the right wires or your angel eyes will blink with your turn signals. LSK has full write up and it works fine. U simply turn on parking lamps to turn on angel eyes
I’ve been looking at the wiring instructions for the Angel Eyes and they state to wire into the Orange/Blue with the red wire and the Black/Blue with the black wire.
That’s what you used right?
lsk had the wiring instructions backwards, just check it with a meter to make sure which is full power. unless lsk switched the instructions they were wrong.
In my last post I listed what Lskoncepts has on there installation instruction as far as the wiring goes:
Are they wrong? :confused:
it is just because they are black. My wife swears that white ones are the same size but only look smaller. You know, an optical illusion.
:confused:
Your probably right, in the installation instructions they show the boxes taped/glued to the back of the headlight so it's not floating around in the wiring. Not a bad thing though... The wiring that "rickztahone" has looks the same as the installation instructions. Tell me "LongIslandLSE" stated that Lskoncepts has the wiring wrong, is that true or did they fix it according to what they have listed and what I posted from them earlier?
