Oxyargon03
Angel Eye means that white neon light around the head light correct? and what is the painted bezel? i have the UA black 2002 LSE V8. Recommend a painted bezel? thanks :headbang:
Oxyargon03 said:Angel Eye means that white neon light around the head light correct? and what is the painted bezel? i have the UA black 2002 LSE V8. Recommend a painted bezel? thanks :headbang:
I've got the angel eyes in. As for the side markers it's looking like end of June or first of July. It's getting close!LennDawg said:when you gettin the angel eyes and the clear side markers in ken?
GrayGhost1 said:I've got the angel eyes in. As for the side markers it's looking like end of June or first of July. It's getting close!
Well, no one else sells an aftermarket headlight for the LS. I built the first CCFL angel eye headlights and a couple of folks on eBay have trailed behind. As I stated in another thread most companies shy away from the big setup costs on small run items. I'm finding this out with the mesh grille setup I've been working.LennDawg said:i am really interested in the angel eyes, but im not sure if i should get them... do you consider them the best aftermarket headlights out, or would you suggest something else?
GrayGhost1 said:Well, no one else sells an aftermarket headlight for the LS. I built the first CCFL angel eye headlights and a couple of folks on eBay have trailed behind. As I stated in another thread most companies shy away from the big setup costs on small run items. I'm finding this out with the mesh grille setup I've been working.
GrayGhost1 said:Sounds good. I'll make the annoucement here on LvC when the clear side markers are available. Trust me, I am so ready for those things to be done!
:BeerohioLS said:In another note Steeda just called me they are in the programing stages of my SCT Xcal 2, I will give you a full report once its downloaded and running.
-Scott-
Yes. I'll have clear bumper side marker lenses for the sport and non-sport LS's. I'll also have the clear lens for the turn signal inside the headlight as well.h2osho said:Ok lets get this straight.
Clear side markers are on the bumber. Yes? Directly in line with my bumber chrome.
Clear turn signals are INSIDE the headlight assembly? Which is actually Amber from the factory but can be removed (leaving it clear or without a lense) and replaced with an amber bulb.
Here's what Silver Frost Metallic looks like.cblood said:So what does the bezel look like painted siver burch??? If you think it will look good how much more for the paint?? I really want the these lights. and the side marker lenses!!!!!
