..only under high RPMS (say 5k or more).
At rest, multimeter shows charging system putting out 14.26 volts.
Morning after the car has sat overnight, the battery (with car off) shows 12.36 volts.
When driving normally, all is fine. WHen at rest/at a light, all is fine.
Saturday I was cruising along in 5th at about 50mph then floored it. Tranny dropped down to third and power was fine, but immediately I noticed the alt and check charging system lights glowing. Came down off the gas, and the lights went out and all was fine.
THis morning, in SST mode, I had her in second gear, then smoothly gave her gas to the floor.. Redlined her, upshifted to 3rd gear. No problem.
About 4 mins later..I tried the same thing, this time alt warning light and "check charging system" light came up. Went off as soon as I dropped the RPMS down back to under 3k.
ALternator is a reman'ed unit put in about 60k ago. I honestly cant recall if I've ever replaced the battery, although I think I did about 3 years ago. Just cant find paperwork. Def a motorcraft battery in there. Battery terminals clean as a whistle and the cables are clamped on the posts firmly.
Serpentine belt is OEM with 145k miles on her now. Was waiting for 150k to do quite a bit of maintenance, including changing the belt. My first instinct is to replace the belt now and see if that helps. If it doesnt..no money lost.
What about the tensioner for the belt. Should that require replacing now?
