is there a remote start along with this alarm?
is this a second gen LS
if these are both right, ive got money on the installer not using enough extra relays to power the ignition harness up,
this may also be the case for 1st gens but im not 100% sure.
all viper remote start systems have 2 ignition wire and 1 accessory wire (the second ignition can be programmed to acc, but thats not important here)to simulate turning the key switch, the LS has 2 ignition and 2 accessory wires, most times you dont have to power up every circuit for the remote start to function. usually all of the ignition wires do need to be powered up since these are what run the motor (older fords had 3 or 4, but some of them where common) and you usually only need to power up the accessory circuit that drives the climate controls.
with my LS, i didn't want the radio to come on when i remote started the car in case i left the radio turn up when i got out of the car, so I intentionally did not power up the extra acc circuit with a separate relay. the weird part is that it wouldn't throw two codes until the fourth time i remote started the car, no matter how many times the car was started with the key in between. so it was a little tricky to figure out because i used the RS every day, but the codes was only popping up every couple of days. and it was the Fuel Level Sensor and something else about fuel system. with the way new cars are and the way everything i the car talks to each other, every circuit need to powered up.
i never had this problem with my 1st gen, but i cant remember if if i added the relay to the system, the LS needs a few extra relays for so many other things. and i had the radio controlled a different way, i had the "ground while armed" wire triggering a relay to keep power from the radio until the car was disarmed/unlocked, which is a nightmare for anybody with an AVIC. he needs to fix the problem
Frank, you need to call the shop and make sure you talk to the tech that did the install and confirm that either he did use and extra relay for the ignition harness (because there are a few other places that one could/need to use on for this car) or that he didn't so that he can fix the problem.
I also have a relay under the dash that makes noises everytime i open or close the door when the vehicle is on. According the shop that installed the alarm, not even Viper could tell them how to fix this problem.
yes thats called the good old "box of bees"
the LS's wires for the door triggers (the switches that tell the computer which doors are open) are negative trigger, but the circuit is normally closed, or ground when at rest and open when the doors are open, most cars are the opposite, and the door triggers show ground only when the doors are open.
so you must pick a new way for the alarm to know when the doors are being opened, the next best choice would be the doom light which is also negative trigger, since it comes on every time any one of the doors are opened. BUT because the LS shut off its computers after a short while, when the computer shuts off, there is a small resistance to ground that trickles through the computer and the alarm thinks that some one is breaking into the cars(the alarm will go off every time the cars computer goes to sleep)
since the resistance is not enough to trigger a relay, you have to use a relay to isolate the dome light circuit from the alarm, BUT because the dome light fades on and off very slowly, this triggers the relay on and off about 50-100 times causing the buzz in the box of bees (the box is the relay of course since its a little black square) i call it a box of bees because when everyone ask me about it, i tell them that my alarm comes with a box with bees in it that get shaken up every time the door opens, and if the door is opened and the alarm is set, the alarm will release the bees (and i dont know about you, but thats enough to make me not want to fukc with some ones car.lol)
as for fixing the problem, it depends on what system you got and when it was built.
all of the responder LE systems (5701, 5901, 5902) that were built in mid to late 2010 till now, have a setting where the door trigger detector circuit in the alarm can be set to normally closed and just hooked up to the individual door triggers(they will also need to be diode isolated(if your tech doesn't know what this means then he shouldn't be working on it)) without the relays.
if your system is an older responder, or any other system, then your stuck with it. what i did was get the smallest micro relay i could find, and wrap it up in about 7-10 layers of dynamat extreme. (i also ran all of the wires through the fire wall so it can barely be heard from inside the car)
sorry for the long winded techsplanation, but i hope it helps
