Airbag Light Coverage
rebeccasmiin
Largo, FL
Hello, I have a 2006 lincoln town car and the airbag light comes on everytime I turn the car on. I was told that it needed to be electronically checked out to see where the problems is. I was also told that it should all be covered under a warranty. My question is that will it cover the evaluation to find the problem and the repairs? Can anyone shed some light on this subject for me? Thank you very much.:confused:
Does the airbag light stay on? Does the rear of the car sag? You might get a better response posting this in the Town Car forum. It could be several different things.
try moving your driver seat forward and make sure the connections are tightly fastened should be found under the seat. this usually happens when u adjust the seat it hits the wires and it becomes loose. How do i know? Because it has happened to me before.
