hello, i have my airbag lights on. its a code 3-2.
i believe it to be a clockspring. the horn doesn't work,nor does cruise control. i dont have the factory stereo no more so those buttons would't be an option..
all signs are pointing to the clock spring.........
ok, the reason i ask is because not to long, i had a PIGTAIL replace when my car was rear ended. the airbag light came on and they replaced the PIGTAIL underneath the driver seat. the job is warranted through USAA insurance so if its the pigtail then it can get replaced again
the codes i have now
b1869 airbag warning indicator lamps
B1932 driver airbag high res/circuit open
31891 airbag tone warn circuit short.
i had the guy at the base hobby shop run up the codes and this is what i got ?
does anyone have any experience with the pigtails.
thanks in advance
thanks in advance
