1996mark8green
Been haveing a problem with my air suspention , started about a month ago was driving in rain storm and all the air in the front suspention went out , pulled over and after a bit it aired back up only to have it do it about 400 miles later . Then it did it the other morning again and then when a came back out later it aired back up as soon as i got into the car and started it. then today i bo out and my battery is run down and the back is on the ground started it up and it did not raise then when i messed with a front sensor it raised part way and then let all air out in front after about an hour pump started and aired it up all the way to let front back out half way to the house . for now i have pulled the fuse ( 50 amp ) to keep compressor system from kicking on and shut off switch in trunk to try to make sure it will not operate a solinoid to let air back out of system . Please give me some sort of advise Iam out of town but have volt meter with me ect to maybe try to track this down Thanks Dave
