Terrance
OK, After reading through all those search threads I have come to the conclusion that I must have a vent solenoid problem. "Check Air Ride" comes on when I get above 100kph/60mph. I can stop, turn off the car, then start it again, run system check and it comes up "Air Ride OK" it only comes on and stays on after being at high speed.
I recently had the tires rotated and forgot to turn off the air ride when they did the work and am wondering if this caused the problem. Would turning the switch off & on again trick the system or is it time for the new and improved spyder valve to replace the stock vent solenoid?
