depending on what your most recent update or the MT2500 it should be able to get the codes by going in and using the Superstar II emulation mode ive done it with mine a few times, ill type out the proceedure.
This is basically from ford, i pulled it from Alldata.
FUNCTION TEST
1. find the DLC, front pass. side
2. Turn the air ride OFF
3. set scan tool mode to fast, set HOLD/TEST to hold
4. turn ignition switch OFF then ON. ensure both doors are closed.
5. connect scan tool to DLC set HOLD/TEST to test.
6. read and record codes.
AUTO TEST
1. find DLC
2. ensure air ride is ON
6. code 10 will be displayed while auto test is running. any faults detected will stop the tests and be displayed on the scan tool. CAUTION: DO NOT LEAN ON THE VEHICLE WHILE CODE 10 IS DISPLAYED, THIS WILL CAUSE A FALSE ERROR IN THE TEST.
7. when code 12 is displayed open the drivers side door and turn the wheel 1/4 turn in either direction, then close the door.
8. read codes
Well i hope this helps in some way, if you need the code numbers ill post them as well later.
Steve
