air ride compressor
lunchmeat
Mt Vernon IL
Where can i get detailed instructions on how to remove and replace the air ride compressor?
its easy, turn off air ride switch in trunk, pull your right front wheel, pull the wheel liner, and look towards the front of the car and you will see it, pull the splash shield from under the bumper, press in the orange collars and hold them in as you pull the line out (repeat 3 more times) unplug the connector at the front of the compressor then 3 bolts (i think 3) and out comes the compressor
