Air recirculation door stuck closed
3.9-LS
Wilmington, NC
I was changing the cabin air filter in this 2000 LS I just bought and noticed the recirc door was closed. I messed with the settings and never saw it open. I only want fresh air, not this recirc garbage.
What settings did you mess with?
Have you done a front panel self-diagnostic from the DATC?
I changed many settings: AC, recirc, auto, fan, temp, defrost...
I have not tried self diag.
Recirc is the one to play with. The system will always select fresh air unless you press recirc or the cooling demand is high.
See what the self diagnostics have to say.
