so yes, finally, I ran the test.
most of you know that I fabricated a custom heat shield that encloses the KKM air filter.
first I took the heat shield off, covered my air inlet that's behind the front bumper to simulate what it would be with just the KKM filter alone.
I used the digital oven thermometer with probe.
for all the temperature reading, temp sensor was 1 inch away from the KKM filter. I ran the car for 10 minutes (time it takes for me to go home) prior to testing. for each measurements, I kept the speed for 5 minutes before taking down the temperature reading (in F)
repeat the test with shield on and uncovering my air inlet.
so here's the result.
ambient temp 70
without shield at idle 172
20MPH 154
40MPH 122
60MPH 102
with shield at idle 167
20MPH 92
40MPH 76
60MPH 71
sorry, no data with lid on the shield. blame it on my laziness.
but I was amazed with the results.
even at low speed, my air scoop is doing a great job of bringing in fresh air and heat shield blocking hot air, with both working, it's doing wonderful job of dropping the intake air temp.
Hope all your air intake work is going well.
ambient temp 70
20MPH 154
40MPH 122
60MPH 102
20MPH 92
40MPH 76
60MPH 71
