jerryg2112
Looking for some help with my A/C. I have a 1999 and it keeps blowing fuse #34 which is 15 amps. It takes about five to ten minutes of driving with the a/c on for it to blow. The fuse does not blow without the air. With the car running in park the motor bogs for a second when the clutch disengages. Is this normal or is the clutch hanging up and maybe drawing too many amps? So far I have changed the fuse a half a dozen times. I've cleaned the cycle switch connection and swapped the relay with neighboring relays. I have cleaned the connector on the compressor. I have cleaned the ground by the battery on the inner fender wall. I have not checked any of the reverse lamps or grounds since that part of the circuit is not active when the fuse blows. There is 14 volts at the relay terminals 1 and 3 with the car running. There is also 14 volts at the compressor connector and the cycle switch. I have a couple of tests for short to ground that are in the repair manual that I am going to do. Any other suggestions would be appreciated.
