Air bag light
1996Mark
SC
Anybody have any idea why my air bag light is on? Its been on since I bought the car, it gets really annoying seeing it lit up at night.
I thought about pulling the bulb, but would rather find out what makes it come on. If I cant figure that out I will pull the bulb. And it doenst flash, its just on constantly
Is it doing the 32 code flash? Then it is probably your clockspring unless your cruise and horn work. Then it's under the seat for the ass detector switch plugin which can go bad.
Both cruise and horn work. So theres a switch under the seat that could go bad? Does the seat have to be removed to get to it?
I haven't had air in a long time, didn't know the clock spring and air ride were inter-related
It's the air bag warning light. You know the SRS.
You can see the plug-in bit from just looking under the seat. It's a yellow wire I think. This is all memory, I'll see if I can find the docs.
