Air Bag Light
jayblev
Church Hill
A couple of days ago the airbag light came on in the dash. it flashes then goes out then comes back on. it does this for a minute or two then just stays on. Has anyone else had this problem and if they have how do i fix it and whats the average cost. I appreciate any help. Thanks
Please search the forum. SRS (air bag) issues have been covered over and over and over again.
The light is flashing out a two digit code. It will almost certainly be the code for the clockspring or the connector under the seat.
Jayblev,
Lucky for you that im not like most of the D-bags who say, "SEARCH!"
i had the same problem a while back and did just a bit of research. when i foudn the problem, i was able to fix it myself.
Im gonna give you the links in order for which they will help you, depending on your situation.
http://www.lincolnvscadillac.com/showpost.php?p=417549&postcount=9
http://http://www.lincolnvscadillac.com/showthread.php?t=63909
Now, if you do find that the code matches the one that shows a problem with the connector under the seat then look here:
http://www.lincolnvscadillac.com/showthread.php?t=65259
If you find its the clock-spring, other than being totally F*****, you can look here:
http://www.lincolnvscadillac.com/showthread.php?t=53760&highlight=clock+spring+pic
Thanks for the info. Yes I am a noob to this forum but not to forums alltogether. Having two young kids to keep up with and a very crazy work schedule, i dont always have the time to search thru various threads. It came on and i got worried and wanted some quick help without taking it to the dealership and getting ass raped in the process. So thank u for the help.
Np dude...i understand. GL with which problem you have :)
isn't it like $100 just to diagnose it and they give you it back if you let them fix it
