Adjusting Door Striker
soduka
SD
When you close the driver side door it's not flush with the quarter panel behind it and sticks out a bit. There's also a some wind noise when moving at high speeds and depending on the wind direction. Is there a specific method, and is it possible to adjusting the striker to make the door close tighter?
Yes, you can adjust the striker plate with a Torx driver. Can adjust it inward to see if anything changes.
Mine will make different wind noises depending on the direction of the wind and the temp.
Adjusting the mirror housing made a difference also.
Staff online
