adapter rings
topher5150
Grand Rapids, Michigan
I'm thinking about getting some cobra rims and don't really feel like doing the hub swap dose any one know who makes good adapter rings
i want to get a set of cobra rs, do they have an adapter rings? or would i need a hub swap.
ugg............I see what Frogman yells about all the time now...........:D
Cobra R's are availible in either the mustang Bolt pattern OR the thunder bird/MarkVIII pattern and offset.
If you get the mustang hub pattern versions you WILL have to do a hub swap.
If you get the VIII pattern.................you won't.
Mike
you WILL need to buy the hubcentric rings with the VIII wheels tho. the wheels are cast witht he mustang hub hole, and the VIII units need the ring to keep them centered correctly.
These rings will make a huge difference and they are cheap too
If you go to the site I posted a link to above you click the link "Products"
It take you to a page where you look on the left hand side and then lick the link "Tbird/Cougar/MarkVIII"
This takes you to a page with all the choices for wheels that will be a direct bolt on for your Mark, offset and bolt pattern... ..
