Accel coils - user feedback.
lincoln_zero
ICE COLD CANADA
So I have read a few posts about these on the LS. Some with great success, others with bad experience using them on their F-150.
Whats the consensus here regarding these coils? I found this thread:
ACCEL Ignition COP install
Edit: I am aware of this.
He's saying reverse the pins so that they will be in the orientation they are suppose to be in (because the Mustang is reversed as opposed to the LS)..
40,000 miles across 5 years on mine (with NGK Iridium plugs), only issue so far was when the wiper arm gasket failed and poured water on #8. Replaced the seal and haven't had an issue since, same coil and plug. The wider boots really don't seal as well as you'd think due to the expansion and contraction of the air trapped in the plug well. Cowl and valve cover gaskets are still important things to watch
