BlacksonAudio
So I just changed the dccv and the hydraulic actuator because the LS was overheating. Now I have an AC that only blows cold when driving... lukewarm at a idle. Pointers
Will FORScan be able to show those reading? I’m trying not to go to the shop if at all possible?
This is one of the procedures you are best opening your wallet for and having done professionally...they will fill the system with dye for no extra charge I'm sure ...this is crucial to do so that you can check for leaks with the black light ..Will FORScan be able to show those reading? I’m trying not to go to the shop if at all possible?
