The whole summer I had ac just fine, then at the end of the summer is slowly went out, now it shows it has too much freon/ pressure in system. I figure I have blockage, or a bad pressure switch. Any ideas? Where should I start?
Well it would stay on constantly running high pressure, it was on but it was blowing hot air, no cold air at all.
What is the Dccv? Would it explain the high ac pressure?
Way in the red. I know this a separate problem but before if I set my auto temp at like 70 my ac would work for alittle bit then my heater would start blowing. And it would be just hot air and it won't blend at all. Is this natural.
I had to change the filter drier o rings beginning of the year cause it all leaked out, so then I put in 3 small cans, I can't remember for sure might of been 2
Now the heater valve and dccv are two different things I assume, my heater valve was changed before I Baught it a year and a half ago.
