Was it scanned and what were the results of the scan? If you scan it the scanner will show you the values for the scan. If all sensors have the same value then it would be computer or solenoid. Please give more details.
It was scanned at the dealer. They said the voltage would dip slightly but not enough to flat line and post a code. The code that shows is to reset and test again.
Gonna try my luck with the hub and will post back.
If you have a proper scanner (which ford should!) it will show the output of each wheel sensor. This will show which sensor it is. I don't understand how the ABS can be on all the time, with no light and no obvious fault.
