Abs dtc 17
dnsherrill
Raleigh
96 base, pulled the dash orange ABS light, and Traction control OFF light
used the paper clip method at red_test plug by passenger headlight to detect my DTC 17: Reference voltage failure, high/low battery voltage, main power relay, main fuse, wire_harness"
I have not yet checked fuses in the power dist box or swapped relay
the factory service manual instructs to troubleshoot using the the 60 pin breakout box 014-00322;
-can I check voltages and resistance levels WITHOUT the breakout box?
OR, are there other EEC-IV 60 or 80 pin breakout boxes I could use to find the problem(s)? some listings on the auction site look similar, but have slightly different numbers, ex. 3225, 3226 see link
