Lownslowlsc
Ok, well as with most lowered coil kits the back of mines been saggy for some time. I want to swap in some t-bird coil's i've had laying around for a couple year's. What is the "how to" when replaceing the rear coil's with new coils? I assume a little more precaution is taken. Me and a buddy did the rear conv years back but I was kinda drinking and not paying attn.
AFAIK:
Put the rear on jackstands
take wheels off
disconnect endlinks
support lca w/ jack
remove upper bolt
Remove lower shock bolt
slowly lower the lca via the jack till the spring is free
replace said spring and install in reverse order?
Does that sound right? Tip's
AFAIK:
take wheels off
disconnect endlinks
support lca w/ jack
remove upper bolt
