A/C Problems
Monet365
Austin
I just got a Lincoln Mark VIII and the a/c worked fine for the first 4 days or so now its just blowing out hot air. I took it to get check everything is working fine its full of freon. Just wondering if anybody has any ideas before I pay $200 dollars to get checked out to see whats going on...........:confused:
Okay! What should I look for? And do you think if i get it vacuum out would do any good?
check all the vacuum lines on top of your motor.
I had same problem you described. Shop found radiator fan was not coming on. They put a big box fan in front of my car blowing on the grill and the AC started cooling again. They cleaned both ends of the fans electrical plugs and it seems to be working again.
wasnt the car over-heating with no fan?
if it is any of the vacuum lines in the system, it will default blow from the defroster only, temperature is either low freon, no fan, blend door
Thanks for all the Input It was the blend door!!!!! I have Nice cold a/c again...........
