A/c Problems!!!!
Rflow50
South Texas
Hello, I am new to this forums. Well this is the problem with my 04 Lincoln LS. Yesterday while driving with the A/C on, I noticed that only the two driver's side vents where blowing cool air and that the passenger two vents were blowing hot air. I checked the A/C controls, I put the A/C on Dual with both temperatures at 60* and it was the same. Even the back A/C vents do the same thing. It seems that only the left half of the car vents blow cool air. I can hear the A/C compressor when it kicks in and out.
Any advice is appreciated. Rick
there have been numerous reports of the 'blend' valve dorr sticking - meaning that some vent blow hot while other blow cold. Most of the time - after shutting the car off and letting it sit overnight - the problem goes away.
I have on heard of a few cases where a part needed to be replaced - which is big labour dollars since they have to pull most the dash.
thanks, this problems started yesterday, i check the car today and is still doing the same problem.
