Is DCCV same as Dual Coolant Flow Valve?
Anyone has a part number for DCCV?
I can't find it online in the parts catalog.
I found this in my CD manual:
«2001 Lincoln LS Table of Contents»
«Group 4: Electrical»
«Section 412-02: HEATING AND VENTILATION»
«REMOVAL AND INSTALLATION»
Valve — Dual Coolant Flow
Removal and Installation
1. Disconnect the battery ground cable. For additional information, refer to «Section 414-01».
2. Drain the radiator. For additional information, refer to «Section 303-03».
3. If equipped with 3.9L engine, remove the auxiliary coolant pump. For additional information, refer to «Pump—Auxiliary Coolant Flow, 3.9L» in this section.
µ 4. Disconnect the connector located at the end of the coolant valve harness pigtail.
µ 5. Note:
The top heater hose has a green identifying mark to match the hose on the dual coolant flow valve. If mark is not visible, identify the hoses for location. This will aid in the correct installation of the hose assemblies.
Note:
Hose assemblies shown with components removed for clarity.
Disconnect the three quick-disconnect couplings from the coolant control valve hoses. For additional information, refer to «Section 412-00».
6. Raise the vehicle. For additional information, refer to «Section 100-02».
µ 7. Remove the coolant valve assembly mounting bolt and the nut.
8. Raise the valve and disconnect the coolant supply and return lines.
µ 9. Remove the bolts and remove the coolant valve mounting bracket.
10. To install, reverse the removal procedure.
l Make sure that the heater hoses are installed in the correct position. For additional information, refer to «Heating and Defrosting» in this section.
l Lubricate the coolant hoses with MERPOL® meeting Ford specification ESE-M99B144-B or plain water only, if needed.
l Check for correct hose installation by verifying DATC system operation.
DEWSCRIPTION:
The dual coolant valves regulates the flow of engine coolant to each half of the heater core. Two electric solenoids, which are individually actuated by the DATC module, are the control elements. The valve contains five ports:
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Port ³ Function ³ Location ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ 1 ³ InletÄcoolant from engine ³ front face ³
³ 2 ³ Outlet to heater core, driver ³ rear face ³
³ ³ side ³ ³
³ 3 ³ Outlet to heater core, passenger ³ rear face ³
³ ³ side ³ ³
³ 4 ³ Return coolant from heater core ³ rear face ³
³ 5 ³ OutletÄreturn to engine ³ front face ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
