The hissing sound is usually a telltale sign that its either low on freon due to a leak or just normal loss. Make sure your compressor is turning on when you turn the a/c on, should hear a click under the hood. If you're too low on freon the compressor wont turn which gets you no cold air.
It was low on gas. Just put a littl in there and it went away and it started blowing cold again. I must have a small leak because I had the compressor changed 2 years ago.
