So, the PCM will turn the compressor off if the high side pressure goes too high or too low, the evaporator temperature goes too low, the engine overheats, or idle speed drops too low, or if it's badly misfiring.
None of that matters if you bypassed the AC clutch relay (11-5 under the hood). Bypassing that relay narrows your problem down to a bad or miss-adjusted clutch. My limited experience says that it just needs to be adjusted. You take the front plate off and you'll find that there are a few shim washers on the shaft behind the plate. Take one of those off and reinstall the front plate and you should be good.
My Ranger (same AC clutch) had the symptoms that you describe. I fixed it by removing one of the shims from the clutch.
Please note that the dealer will not change just the clutch. They will insist on changing the AC compressor with the clutch. I don't know if they will be willing to do the air-gap adjustment on your existing clutch before condemning it.
6)Does a new compressor come with the clutch/pulley/etc attached?
May or may not. I changed out my daughter's (2000 V6 LS) compressor in a couple/3 hours or so. That was with a compressor where I had to swap over the clutch and pulley. With an all inclusive compressor the job would have taken much, much less time. Not really a difficult job, just a pain as you're working over your head, on your back. I would just replace the whole thing. IIRC, you can get a complete compressor (field, clutch, pulley...) for under ~$300.
Where would you suggest? I checked Team Ford and they list a compressor for $362. Wonder if that is a "complete" compressor.
So you replaced just the compressor and not half the parts along with it. Did the repair turn out ok? A/C worked fine after replacement?
6. They usually do from Ford. Probably not so much for aftermarket.
So as it would turn out it didnt work at all yesterday and today the a/c was working perfectly fine. Cant be compressor or refridgerant level, maybe some clutch component. Possibly some kind of short in wiring somewhere. Whatever it is it can work perfectly fine one day and do nothing the next. I'm dropping off at dealer tomorrow to have a thorough diagnostic done. Could be a $40 sensor, could be a wire that needs to be fixed, or could be the clutch. Whats frustrating is the random nature of the issue. The service advisor did say they would do a part replacement on just the clutch or clutch coil but pointed out that with a compressor that has as many miles as it does it doesnt really make sense to put a new clutch assembly on a 176k mile compressor, and i agree. I did call Team Ford and part#2R8Z19V703BA for a compressor does include clutch and pulley assembly. Cost is $412. The cost for the clutch components (clutch, coil, plate) would total around $100. So for $412 i think its worth it to add in a new complete compressor. Again all this depends on whether they can pinpoint a short or sensor or something secondary.
Freakin LS!!!! After dropping $3000 for a new tranny i will damn sure be keeping it for as long as it will last.
What is magnetic field? What is the part? Clutch coil? Air gap adjustment?Reminds me..... Years ago our Sable had a similar problem. Eventually it quit cooling at all. Turned out to be the magnetic field. It was replaced and the A/C worked fine until we traded it in on the 2000 LS.
I would still get that other compressor from Rock Auto. The warranty is better and the unit is considerably less expensive. Assuming you do the hard part.
What is magnetic field? What is the part? Clutch coil? Air gap thing?
I plan on going the easy way by having dealer to the "hard" part and they will only allow an install on an oem part. Wont install an aftermarket.
Clutch coil. Roger......
Interesting. That part alone is only $46. Does the compressor have to be removed to replace clutch coil?
Alldata shows removing the compressor. It also shows 1.4 hours labor.
Is Alldata a pay service or a free site? I'd love to know what to expect when a repair is needed.
what does 11-5 mean? Exactly where do you bypass the clutch relay so that the clutchSo, the PCM will turn the compressor off if the high side pressure goes too high or too low, the evaporator temperature goes too low, the engine overheats, or idle speed drops too low, or if it's badly misfiring.
...A compressor will NOT kick on if the pressure is too low, this has to do with pressure switches in the compressor itself and almost nothing to do with the PCM. ...
Yes, I do understand you meant to jumper the relay when removed. It's just that there are 6 flag terminals on the back of this relay and 6 female slots in the fuse box. Which 2 do I jump between?
