Icarus
You didn't need to remove the lines or even loosen the compressor to do the clutch on the FS10 our cars have...
Take the serp belt off, undo the little bolt on the center nose of the compessor (8mm iirc), pull clutch off, take out snap ring holding pulley on, slid pulley off (watch you don't lose any shims in there), get a puller for the field coil and pull it off...
Use a puller to pull the new field coil on, install pulley, snap ring, shim(s), clutch and bolt, check the air gap and adjust if needed, put belt back on and go (its a good idea to cycle a new clutch on/off 15-20x at idle to burnish it in so it grabs better)...
