Blenderhead
OK, at the shop we got a 99 cadillac STS in, that has a weird problem. It overheats after almost exactly 30 mins at 2500rpm/highway speed. You can drive the car around town all day with no problems. You can leave it idling all day with no problems. There is no smoke or misfire or anything like that. You can take the car out and flog the hell out of it, and it won't overheat. Leave it at a steady 2500rpms, and it will overheat after almost exactly 30 mins like clockwork. When it overheats, the fans are working fine. Another shop already replaced the thermostat and did a coolant flush. Also on wierd thing is when it overheats, the message center says "battery not charging", but that goes away as soon as it cools back down, so I don't know if that's just the alternator getting too hot when the engine overheats.
Anyway, has anyone ever had something like this? It's a 4.6 Northstar by the way.
