98 matk viii key pad doesnt light up
Lincoln Mark VIII
  1. Karnage
    Karnage New LVC Member
    3
    Oct 5, 2019
    Littlerock Wa.
    New here and i did a search. My keypad isnt lighting up now. It did a couple days ago. Is there a bulb that may have burned out? Interior lights all come on. Can lock and unlock doors, pop trunk etc so it works. Just not lighting up now. These cars have quirks for sure.
  2. joegr
    joegr Dedicated LVC Member
    19,886
    1,498
    Dec 10, 2005
    Gulfport
    All the other Ford/Lincoln/Mercury keypads that I have seen (including 1994-2006) use LEDs soldered onto the PCB that has the switch contacts. You probably need to replace the whole assembly.
  3. Karnage
    3
    Oct 5, 2019
    Littlerock Wa.
    Thats what i figured.
  4. 91 LSC SE
    91 LSC SE Dedicated LVC Member
    535
    20
    Sep 25, 2008
    Canada
    or pull it out see what kind of LED's and purchase replacements and solder them in.
  5. joegr
    19,886
    1,498
    Dec 10, 2005
    Gulfport
    My guess would be that the keypad rubber has started to split and is letting water get to the PCB. Eventually, the whole thing will fail. At least, that what happened to one of mine (99 Grand Marquis, I think).
Share This Page
