98 Mark VIII
wallsr2
Athens
Got a problem getting into reverse, will not disengage, plus no brake lights, any suggestions?
Hey wallsr2! Type INTERLOCK in the search bar, you will find a whole load of threads relating to this issue. Your answer should be there.
Im always scared to work on that switch.
why? its simple 2 wire switch, just under the dash on the pedal arm, usually just a broken wire, check for power on one, with the pedal up and should be power on both with pedal depressed, if no power at either then look at fuses and start figuring out why you blew a fuse. 99% of the time the wire will break at the switch. there is a taurus recall kit that has a new switch and a replacement pigtail that are the same
just to clarify the brake light switch is NOT the one for the recall
Lol. Dont you get it chicken? Boo - Scared??? :rolleyes:
yeah,its not that scary...they should call it the Casper switch,then unity will know its safe to work with..:shifty:
