Wanted 98 Mark VIII Really needs a Burl light control surround.....
bhans40
Elyria Oh
For a 98 Mark VIII. The wood grained light control surround. The same color as the rest of the wood grain in the car.....Mine went away.....I have all of the rest of wood grain except for this one.
I do not have the 98 Mark VIII trim components you need but I do have a need concerning a 98 Mark VIII having bought one as a donor of the engine, trans., PCM etc. which was installed in a 1954 Ford Victoria into which I am now install an aftermarket tachometer and need to find the wire (signal source) to feed the Autometer Tach.. I am missing pages 57.4 to 58.9 of my 98 Mark VII Electrical & Vacuum Troubleshooting Manual where the insturment wiring is shown. Also, I do have a box full of leftover wiring and electrical components such as LCM, Wiper Module, connectors etc. which you may have a need for. Since you are in Elyria & I am in Medina, Ohio , maybe can help one another with Mark VIII parts and info.
I wouldn't mind this at all....Although I do not have any of the trouble shooting manuals....I have found in the past that if I went to GOOGLE and imputed what I was looking for I could usually find the info I needed....You may also go ahead and purchase the manual
Thanks for your reply. I do have the electrical & vacuum repair manuels for both the early Mark VIIIs and the later Mark VIIIs. My issue is for adding an aftermarket Tach to my 1954 Ford Victoria inwhich I have installed a 1998 Mark VIII engine, transmission,PCM & otherMark VIII stuff but I do not have an Mark VIII insturmentation. So what I need is guidance on a place to get a signal to operate an Autometer 2 1/16"Tach. Any Mark VIII parts I have are lefe over from 2 Mark VIIIs I bought as donors for my 1954 Ford build.
