This problem is very intermittent....the rpm's steadily increase and then return to normal. Most noticeable when stopped. It will be idling higher then normal (don't know specific rpm's) and if you put it in neutral the rpm's steadily increase. My first guess would be whatever throttle control mechanism this car uses. Had a similar problem on a T-bird. Any ideas to a possible cause would be appreciated. Thanks.
Robert
Robert
