KevinD
Hi you Lincoln folks,
I just replaced 98 continental air suspension compressor pump, yet it sounds louder & vibrates a bit when pumping
we replaced the 2 rear air suspension bags (a year apart) already.
I've heard this same sound, 2-3 years a go & then it stopped this louder pumping sound with a bit of vibration but I think the elevation to a higher ride height stopped at that time too but I didn't notice.
On replacing the pump, it now goes to the higher ride height.
The new pump bought, from on-line parts place $107: needed to use the old dryer because new dryer was too big to install, so used the old factory dryer.
a mechanic says "Not the dryer, maybe a cheap Chinese mfg pump, its louder but it works" but suggests 'get used to it'
But this sound occurred 2-3 years ago with the factory pump
Any idea of the issue causing louder vibrating pump? so I can fix it..
thanks for your thoughts KD
