97 oem stereo wiring/ switched 12v?
Lownslowlsc
N il
Anyone know what color it is? The slim plug (grey) is were one of the switched 12v wires is. Which is it? The plug colors on the plug are
red
black
black/grey stripe
red w/black stripe
black w/stripe
blue
I checked red and its constant 12v. blk w/grey stripe and red/blk do nothing..Didnt check any of the others.
Previous owner had something installed back there and the red,blk w/ grey stripe and blue were allready tapped into for what i'd assume was a sirus/xm doohicky.
If i cant find it i'll just use my "add a fuse" that all my accessories are hooked up to. But i really want to keep the modulator on the same fuse as the radio and not add another to my acc line..It can handle it but im being picky and would rather find the wire behind the h/u.
Anyone know which is a switched 12v?
hmmmm...Neither of the blk w/ striped wires looked to be black/yellow...Guess ill just cross my fingures and try the other blk one. Thanks
ok, for whatever reason the first blk/striped i checked was the right one..I think i had a brain fart and forgot to turn the car on..:)
Also the wire was def not blk/yellow..its def blk/ shade of grey..
But thanks limit, you led me the right way..Any chance you have all the other wires color/function? I have the amp wire colors/function but not the ones behind the h/u.
