97 Mark VIII pulling to the right when braking
drobs5
United States
So I've searched and it looks like the most common problem when this is happening is the strut rod bushings or lca/uca ball joints. Does that sound right? Is that where I should start diagnosing this problem?
I would check out the front brakes while you're at it. Make sure you don't have a sticky/leaky caliper etc
Or a bad left front brake hose preventing the left caliper from working..
Best to get the wheels off the ground and spin each - do they both spin freely and evenly?
So I did the back up fast and hit the brakes deal tonight and sure enough the car pulls to the opposite side. Guess I'll be checking out the suspension asap.
