97 LSC Manual Transmission Conversion.
lots of threads here on the process - are thinking 5 speed or 6 speed. Search you will find info here.
Did you consider a T-Bird super coupe as a donor car. Manual trans, easy to hang a clutch.....Even the ECM might be compatible.
Were the turbo coupe's around in 97?
Not sure, my son had one, do not remember what year it was, it was based on the MN12 platform chassis. Mark viii is based of a modified version, FN10 platform.
Actually, I was referring to the supercharged Essex pushrod V6 motor that made it a Super Coupe. Produced from 89 to 95, It was mated to a Mazda 5 speed manual, M5R2.
Had never heard of them till now. I have a 4.6 liter V8 32 valve motor that the tranny needs to sit behind.
