I been waiting to fix the air ride or spring it. Last year I tried to back it up in my gravel drive way with the frame draging on the gravel Frames scraped the gravel and I lost a brake line. Its so low to the ground I can't get a clothes prop to slide under the mark. No jack will get under it. Outside of getting the car to pump up what other ideas would get car up off the gravel enough to get a jack under?
you'll have to just get some blocks under the wheels somehow. some 2x4 or 2x6 should slide in front or behind the wheel to drive up on. keep blocking/driving up until you can get a jack under.
