sprocket
Here's the symptoms:
1) Hard to start. Requires putting the pedal to the floor.
2) After starting engine revs up to around 2000 as if to clear extra fuel. May drop down and die. May drop down then climb a little above 1000 the settle back to about 800.
3) Will die when I put it in gear. I then have to repeat 1 and 2 and it is just as hard to start.
4) While it is idling, engine temp will climb and with enough restarts and if it idles long enough it can get to the top of normal.
5) After idling for several minutes I may be able to get it into gear. I have to finesse the gas pedal a little. Power dropping it into gear doesn't seem to help.
6) Once in gear it stays running. Engine temp drops as I drive it around and ends up in its normal place. This car has a 180 thermostat.
7) Gets terrible fuel economy. It's probably off by like 6mpg or more.
8) Sometimes the RPM at a stop wants to climb above 1000, sometimes not. Engine temp will climb a little while in gear, at a stop.
9) If I take it out of gear and then leave it running while I go into the store or wherever I am at it may die when put in gear again. The temp will have climbed too. Then the whole process starts over.
What I have discovered so far:
1) I checked codes and there was a PO125 for insufficient coolant temp to go into closed loop. There were 2 O2 sensor codes but I think they were there before. PO161 was one of them I think. I should have wrote them down before clearing because I wasn't concerned before because the code from before was for after the cat but now I can't remember what they both were.
2) I found a leak in the air cleaner. The previous owner epoxied the holes shut for the resonators and the smaller one had a chunk missing. I was at a gas station when I discovered that so I duct taped it shut. I think it is holding but maybe not. I know that would cause serious running issues.
3) The coolant in the reservoir is NOT frozen.
4) When I got home just now, after driving it for quite awhile, I loosened the reservoir cap while the engine was running. There was no pressure. There was no hiss. I could stick my finger in the coolant (which was full) and it wasn't all that hot. Of course it is -15 outside.
I don't know what the problem is. Please help me if you can. Both my other vehicles would not start and I have one battery at the APS getting charged. Hopefully I can limp the Mark VIII there and back to get the battery and then the van will start.
