95 thunderbird 4.6
mark82nv
biotechnical engineer
aurelia
what thunderbird parts work for our lincolns? is it just the supercoupes? or will the 4.6 work ?
just wanted to make sure the sway bars and such are interchangeable can get car for 500 strip it out sell the stuff i dont need anybody need anything from it?
ok no conversion and not sure about trans till i go check it out
front suspension except for the UCAs
rear suspension except for LCAs and brakes, if their drums
think that's about it
Front uppers will work. It's a bolt-in. You just have to take the little tab for the height sensor off the Mark control arm and weld it to the T-Bird arm. It's a PITA and probably not worth the effort, but it will work.
completely different 4.6 (SOHC vs. DOHC)
Yep. The Mark's block is also aluminum while the T-Bird's is cast iron.
