94 not starting
I think we went over all that and he found nothing. New filter, has pressure but we dont know how much without a gauge reading.
I forget, did you replace the fuel pressure regulator yet?
ya i replaced the fuel regulator. im going out now to get starter fluid and maybe a pressure gauge if there not to much. i want the one that stays on the fuel rail so i dont know the cost but ill see.
Careful with the starting fluid. If your timing is off you looking at a pretty big back fire :) Scare ya into next week!
well my friends dad is coming this week to pull the codes and help me with it. sence i have insurance i can drive the car now im tring to get it running as fast as i can. well any ways i went to autozone and had them look up a fuel pump the guy was like wow your not goin to buy this i asked why and he said this is why, $319.99! i was like yup your right.
What was the fuel pressure reading? Get it yet?
Walbro 255 $99 You can go with a 190lb also, the 255 is reportably louder.
im tring to get a reading but the lack of a gauge isnt helping.Well I dont know if this would have helped but when it was running it had a ruff idle and hesitated when accelerating. im not getting any pressure off the fuel rail besides air.
hmmm... Sounds like you're picking up air between the fuel pump and the fuel rail. But if it's "compressed", then why is it not escaping through the hole where it's leaking?
Here's a silly question... Do you have fuel in the gas tank? I mean, certain tha you have fuel in there?
If you do, sounds like either you have a leak, or the fuel pump is sucking air from somewhere. But if you've ever seen the fuel pump canister, you'd understand that's damned near impossible to do, unless you're out of fuel.
Even so, I don't think the fuel pump can actually compress air too well, since it's designed to move liquids not gasses.
Start the car, get a rag, and see if you can purge that air through the schraeder valve. Even though, that air should purge by itself when the car is running, through the injectors.
Are you SURE you're working on the correct valve? Take a pic of the valve and fuel rail you're working on. Not calling you an idiot or anything like that, but I'm starting to wonder if you're not purging your AC freon.
this one
its been 6 months and the car has no fuel pressure for shure. a friend of mine has a 93 mark that had the same problem and he says it was a computer on the drivers side of the car by the upper strut mount that had gone bad and gave it no fuel pressure. he's going to coming over to take a look and put a computer in and see if it will start. im thinking thats what it is cause of the water.
My best friends father is coming down to my house this weekend and taking a look at my car so i know its goin to be running soon because he works on fords all day, every day. the fuel pump is not running so there is no fuel pressure at all.
What he said.... he replaced the relay, and I assume checked any fuses. He gets pressure at times, but not always...
New pump time! Go with a Walbro 255, $99 and it will work well. It can be noisy, so if you dont want that, go for a Walbro 190 and you will be happy.
well I finaly got the fuel pump and it runs like a champ. the new mufflers are sick and its getting some new blood tomarrow and it got new shoes.
