I have a 93 Mark VIII, only 71 k miles on it. Noticed message center saying low coolant so I popped the hood, could barely see any in the overflow. I added some water to the overflow (I know you aren't supposed to add there but I didn't have any tools for the crossover). Well I started the motor and drove around the block, there was an air bubble and the coolant temp started fluctuating. I turned on the heat and when I got back, turned off the motor, the coolant I added had dissappeared from the overflow. No leaks that I can see, no coolant in the oil, water pump replaced around 10k miles ago. Any ideas?
